so is that world hunger sorted?
Was thinking about joining Engineers Australia to make my CV look better and basically opening the door to international jobs (not that im gonna leave) and read one of their magazines and was like
Biggest load of wank I have read since finishing tertiary education.
I think Engineers Australia is only beneficial if you're doing your post grad studies in engineer -> Charted Status.
Apart from that, no use paying a few hundred dollars a year to be a member....
pretty much.
could ask the patrick though. he should know best, being employed and all.
I pay nearly $1K a year to become a member of Chartered Accountants
All i get is magazines quarterly that I throw in the bin
Is that where they take you out on a boat and you count all the BASs?
Oh how I dislike BAS's
Did you get my BAS /bass fish pun? Nobody makes accountancy puns like me.
What's better, when clients forget to do them or when they don't do them properly?
contiki tour = overpriced brothel
Disagree.
A lot of tours from what I hear you can sleep in a different bed every night, however you can still have fun in other ways and do heaps of stuff in a short amount of time.
I went to NZ for 13 days, both islands and did a shit ton of stuff. $350 flights return (in 2010 after first earthquakes) $1500 for 13 nights quad-share. Every 2nd place we stayed at didn't have quad-share so got upgraded to twin-queen share. didnt have to book a thing other than contiki and flights. so nice not having to organise transport and accommodation.
we were lucky and had a good tight-knit group (went by myself) and only one person got laid, and it was to a local lol. 40% were Aus which is apparently very rare for NZ trips.
However, the contiki Europe trips are a different story. accommodation is cheap to mediocre hostels with little flexibility as far as time restraints and activities goes.
If I was to go on a another tour, it would be with Intrepid for more interesting locations.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
