so is that world hunger sorted?
Was thinking about joining Engineers Australia to make my CV look better and basically opening the door to international jobs (not that im gonna leave) and read one of their magazines and was like
Biggest load of wank I have read since finishing tertiary education.
I think Engineers Australia is only beneficial if you're doing your post grad studies in engineer -> Charted Status.
Apart from that, no use paying a few hundred dollars a year to be a member....
pretty much.
could ask the patrick though. he should know best, being employed and all.
I pay nearly $1K a year to become a member of Chartered Accountants
All i get is magazines quarterly that I throw in the bin
Is that where they take you out on a boat and you count all the BASs?
Oh how I dislike BAS's
Did you get my BAS /bass fish pun? Nobody makes accountancy puns like me.
What's better, when clients forget to do them or when they don't do them properly?
contiki tour = overpriced brothel
Disagree.
A lot of tours from what I hear you can sleep in a different bed every night, however you can still have fun in other ways and do heaps of stuff in a short amount of time.
I went to NZ for 13 days, both islands and did a shit ton of stuff. $350 flights return (in 2010 after first earthquakes) $1500 for 13 nights quad-share. Every 2nd place we stayed at didn't have quad-share so got upgraded to twin-queen share. didnt have to book a thing other than contiki and flights. so nice not having to organise transport and accommodation.
we were lucky and had a good tight-knit group (went by myself) and only one person got laid, and it was to a local lol. 40% were Aus which is apparently very rare for NZ trips.
However, the contiki Europe trips are a different story. accommodation is cheap to mediocre hostels with little flexibility as far as time restraints and activities goes.
If I was to go on a another tour, it would be with Intrepid for more interesting locations.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
