so is that world hunger sorted?
Was thinking about joining Engineers Australia to make my CV look better and basically opening the door to international jobs (not that im gonna leave) and read one of their magazines and was like
Biggest load of wank I have read since finishing tertiary education.
I think Engineers Australia is only beneficial if you're doing your post grad studies in engineer -> Charted Status.
Apart from that, no use paying a few hundred dollars a year to be a member....
pretty much.
could ask the patrick though. he should know best, being employed and all.
I pay nearly $1K a year to become a member of Chartered Accountants
All i get is magazines quarterly that I throw in the bin
Is that where they take you out on a boat and you count all the BASs?
Oh how I dislike BAS's
Did you get my BAS /bass fish pun? Nobody makes accountancy puns like me.
What's better, when clients forget to do them or when they don't do them properly?
contiki tour = overpriced brothel
Disagree.
A lot of tours from what I hear you can sleep in a different bed every night, however you can still have fun in other ways and do heaps of stuff in a short amount of time.
I went to NZ for 13 days, both islands and did a shit ton of stuff. $350 flights return (in 2010 after first earthquakes) $1500 for 13 nights quad-share. Every 2nd place we stayed at didn't have quad-share so got upgraded to twin-queen share. didnt have to book a thing other than contiki and flights. so nice not having to organise transport and accommodation.
we were lucky and had a good tight-knit group (went by myself) and only one person got laid, and it was to a local lol. 40% were Aus which is apparently very rare for NZ trips.
However, the contiki Europe trips are a different story. accommodation is cheap to mediocre hostels with little flexibility as far as time restraints and activities goes.
If I was to go on a another tour, it would be with Intrepid for more interesting locations.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
