Oh if she doesn't mind being around meat, go to Papparich! It's cheap and it's really good food. My gf is vegetarian and liked the stuff they had there.
Awesome, do I need to make reservation on Sat for lunch? Or would I be good to rock up?
So much for Evos being the new import to own. Craze lasted like 6 months, now everyone hates them lol
I like the evo, it's just gutless... which I plan to fix when i have ca$h
that's why you buy an entertainment book, buy one get one free so it does cost $5-$6 a burger
276251_Papel-de-Parede-Meme-Are-You-Kidd
chef's don't do entertainment books.
I thought if you used one of those books the chef spat in your food.
or at least used yesterdays leftover ingredients they were throwing out
not spit....
but you will definitely get worse food...
chef will definitely cheap out on the food though... portion size, expensive ingredients and effort. you will also get the oldest, shittest piece of steak/fish etc.
They will also either push the food out right away to get you out and a paying customer in, or put your order to the back of the queue.
I did this every time. without any guilt.
and before you get all up in my shit about it, think about it from the chef's POV
1) people that use the guide are not return customers, they only come once a year at best.
2) even if you try to give them the good shit and it's awesome, they are most likely to go to somewhere else next time to use more vouchers
3) better off to keep the good shit for your core customers, that spend more and will return.
4) experience shows that most of the time they come in, use the voucher, drink free water or 1 glass of wine at best don't tip and are more likely to be rude to waitstaff.
I see where your coming from but:
Why does the owner then advertise in these entertainment books?
If it is for increased advertising of the restaurant then surely it is in the best interests of the restaurant to serve good food to the customer so word spreads.
Disclaimer: Have never owned one of these entertainment books
overall it's a profitable venture... nothing like a restaurant full of paying customers every night though..
end of the day it's guaranteed custom but at a lower return than real customers
of course... that's restaurant tactics 101... but it goes a lot deeper than that in practice
you have to hedge your bets, so you do.
also, work in restaurants for a while and you start to notice that a high percentage of voucher customers complain about every little thing possible and are never happy anyway lol
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
