I just love the irony that the remark only becomes racist when politically correct people say it is; they make it racist.
Were it said to a white player with the same intention behind it, no f**ks given that day.
Where's that South Park episode when I need it...
wait... wut...
I just looked again
she called him an APE? and that's it...
a grown man... a grown fucking man, playing a sport with a history of sledging, gets called an ape by a 13 year old girl and he has her ejected...
I retract my previous "delicate flower" comment and am replacing it with "whinging douchebag"
what a fkn girl
OMG it gets better...
The visibly upset Swans star stormed off the ground after the slur, leaving the rest of his team to celebrate a 47-point win.
baaaahahahahahaha...
OMG what a ghey!
baaaahahahahaha
had to google him...
what a delicate little flower he is
Gee, thought he was a household name!
I think because its an indigenous round is why he got so worked out
In any case seeing the girl shit scared and kicked out gave me the lulz
The museum of tolerance?
Nah the one where half the town thinks the town flag is racist cause it depicts a white stick figure hanging a black stick figure, and the kids don't see it as racist cause they just see it as one man hanging another. Girl didn't even know what she was saying, the PC fags and Goodes made the comment racist by embracing the word as racial slang for a black person.
1) he would be unable to see through his tears
2) his hands would be busy wiping his prescious little eyes
3) he'd probably be more interested in flinging poo around than fighting
Nup...looks like just another BN but with more flavours and smaller packages. Works out about the same price. Also says more gm protein per serving, but the serving size is 40g vs BM 30g. Much of a muchness IMO, give it a shot if you want!
Did Brent get his wheels off lol?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
