i've been sleeping 4hours/night for about 3 days straight.
assignments brah. dat unilyf
and now to head to school, because some excel sheet with macros doesn't work on excel for mac.
4 hours sleep is bad ?
I go to be 11ish every night and get up for work at 3:30am
4 1/2 hours sleep then 10 - 12 hours work everyday all for a slightly above avg wage
baker? butcher?
baker? butcher?
I work for Auspostget around 48k a year.
Thinking about leaving and become a PSO.
well you are really going to hate me for this... but...
the average wage in Australia (from the Bureau of Statics) is....
wait for it....
keep scrolling...
nearly there...
$72,800
i'd say it's more likely from executives and public sector employees etc.
if it was the mines lifting aust then WA would have the highest average, however it's currently Canberra @ $85k
$5.2 million dollars just to get e-tax working on Mac aye....
Sounds a bit Myki to me
Eh.
Tony does mine lol
Jah mun
the Median wage is $57k (in aust) which is a more accurate representation of the average australians actual pay
Yeah that seems a bit more realistic
If you don't get enough sleep in a day. Go to sleep earlier. just sayin
UPDATE: EDDIE McGuire will meet Collingwood chiefs to decide if he should stand aside as president after his "King Kong" reference to Adam Goodes.
Read more: http://www.news.com.au/#ixzz2UjM6dUiU
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
