& also lol Alvin, I handed in my last assessment due on Tuesday night... and that was for an Arts subject. This semester has been alright assessment wise... but just means everything will be riding on exams, fffuuu.
Haha nice sig also.
still got 3 more assignments due this sunday/monday morning. And spent 12 hours in school yesterday trying to remember simulink.
and i've got one paper, right smack in the middle of the exam period, if it was earlier, i would be able to go to brissie earlier.
and because there aren't any nice azusa ones on animesuki, i'll just have to settle for tsukiko.
Sounds balls, bro. Hang in there. On the plus side, it's just the one exam huh? (Besides it's less-than-ideal timing). SOON it will be over.
I rate tsukiko over azusa anyway. *shrug*. Poker face lulz.
not too fussed about it anyway, its an easy paper, since i only really need a 40% in that paper.
and, even though i like azusa more, i'll have to admit, tsukiko is very cute too. and cute works for me.
SYDNEY coach John Longmire has not ruled out Adam Goodes not playing this weekend due to his distress over the racism saga.
The Swans host Essendon in a blockbuster on Saturday but the two-time Brownlow medallist is still no certainty to play because of Eddie McGuire's comments linking him to King Kong.
It comes on the back of last Friday night's incident at the MCG where Goodes was labelled an "ape" by a 13-year-old Collingwood supporter.
Longmire says the club and Goodes are taking it one day at a time.
ok... Goodes doesn't need a slap... he needs a fkn bullet
In time you will, as the other Victorians have, get used to Hamish hating absolutely everything that was not initially spoken of, or better created by himself
So hamish was a Hipster before being a Hipster became too mainstream.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
