I only ever eat the glazed donuts
But would be happy to eat on of the other ones right now
Also would mind a whopper or quarter pounder. Come at me lunch time!
So hungry now :)
Original Glazed Krispy Kreme = Win!
Wish Hungry Jacks would bring back the XXXL Burger!
yeah no thanks.
I'll stick to my rice noodle stirfry leftovers.
Why not have both?
*Cue Mexican Stereotype Music*
Maybe if they actually looked like that when you bought one...
Don't worry L33SH, at least it taste good :D
Lol Jamie you fat kent
That looks pretty big
Yeah man it's the Ultimate Double Whopper!
You should have seen the XXXL Burger = 3 x Beef / 3 x Cheese / Sauce / Bread.
It's like eating a cow...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
