Good luck, Aaron. Good that you're making the change. If you're looking to cut though, seriously, train hard, and diet harder. That doesn't mean stop eating, it means start eating right/healthy. It will make a world of difference. My $0.02.
This. What you eat > Exercise
However if you're wanting to lose weight, calories in v calories out.
Agreed spotter = dem extra 2-3 reps
Come November i would of been hitting the gym for a year, will post up some compareo pics then for shiz!
Birds kept me going the first few months, but now doesn't matter I go regardless!
aaron, probably better to start with the birdmang's advice than to wait to settle in and learn to do stuff wrong.
This...
You come to me with bad habits and I'm more likely to throw a barbell at you. I work best with noobs on a clean slate. I make you balanced.
I'm not a noob lol.
I've got the trainers there showing me how to do things standing correctly and not swinging and bouncing etc.
When I say balance I mean balancing dim bells and bars..
I literally wobble
fuark the old 80s f1 turbo cars were insane.. upto ~1400hp in qualifying and manual shifting! just crazy wish we could see them race these days
http://www.youtube.com/watch?v=Id3wmT0UrMk
the guy in this vid says 330km/h on the straight, now take into account the brake distance and corner speed difference compared to cars these days.. awesome acceleration
Edited by UNR33L
I'm not a noob lol.
I literally wobble
Gym trainers are shit.
You're a noob.
Come to the dark side.
Couldn't find shit. Google said try Kanye West. Get a photo for me. Ask him what he benches, deadlifts and squats and report back here with findings. Then make him prove it to you. This is your first task under my guidance!
installed dash cam. nek minnut, i see me old r33. dat coinkydink
How you set it up? I got a gopro black collecting dust. Wouldn't mind using it for something.
Am paranoid people break in to take it if easily spotted.
Ceebs removing every time I park car.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
