Nah can't see anything with the way the soarer front bar is designed. Nah won't be laggy at all. Should be like a normal engine mounted turbo.
Scott's done a brilliant job as well. I'm sure he'll see this and post pictorials, if he wants
Ohhh yeah we've got little fast baby turbos...
Big turbos have already got a bit of lag, and with the volume of air they're blowing the pipe lengths are not even a consideration in comparison
It is external gate...
As the turbo is 4-5M back from the engine it shouldn't get too hot, there will be a heat shield over it all, and hopefully carpet back over the lot. I have to test it with an infra-red thermometer on the dyno first.
The cooler is 220 x 100 x 700, front mounted and sprayed black. You can't see it from the front of the car thanks to the large fins on the bar, and the long nose.
I wasn't going to fit one, I wanted him to just run ethanol for det resistance, but the tuner was a little worried.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
