Oh look it's the FB justice mob, emotionally knee jerking over something again. Had to lol at all those dumb bitches saying they'd kill the cops if it was their dog.
So savage over a dog being killed when it tried to attack someone...go down to the f**kin pound and pick up a dog, they get killed there daily.
I'd be able to kill the cop if it was my dog, handcuffed and on the floor with a knee in my back and gun to my head, I reckon I'd be pretty capable.
No... you'd be angry... this actually doesn't translate to physical ability.
you'd just be handcuffed and on the floor with a knee in your back and gun to your head... with a dead dog... angry
Sarcasm wasn't evident enough?
If a dog was about to attack you, tell me you wouldn't do anything to stop it.
When I was young I got bitten by a German Shepard. Only thing I had with me was roller blades. That motherf**ker got hit as hard as I possibly could.
Cops should have let the owner go to the dog in handcuffs, that's all it wanted.
Hilarious people saying Rottweilers aren't a savage breed...cause a Maltese Shihtzu would have done the same thing...
It's an old video as well I think. I'm pretty sure I saw it a whole ago when I was on fb. And it started a whole whinging protest. I remember having an argument with one who was obsessed with fur coats. And asking her what the difference was, I lost a Facebook friend that day lol
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
