Does anyone here have a Python alarm? Mine works but the previous owner turned off the siren with the key and subsequently lost the key. Have tried a few different keys from different alarms but nothing works so I'm left to find someone with this alarm. PM me if you know anyone who does have one!
it's not that cold. gonna hit up manly and then a Brunswick-risqué housewarming party. expecting many Asian hipsters.
Yokohama Winton track day
http://www.yokohama.com.au/en/ADVAN-Motorsport/ADVAN-Neova-Cup/ADVAN-Track-Days.aspx
discount if you use advan tyres
Leigh, did you take your car to calder for the drags? Curious to know how fast my ship is...
Anyone else having a quiet night? Or am i forever alone.
Took it to Heathcote, pretty sure calder don't do drags anymore until summer!
Get farked Leigh
:D
15inch screen
Radeon HD 8970M 4gb gpu
i7-4800mq
16gb ram
256gb ssd
750gb hdd
dvd burner drive
$2500
Pro:
- Larger screen
- GPU twice as good as other option
- Slighter larger ssd
- DVD burner/reader
Con:
- Heavy
- Bulky to carry around
- $200 more
or
13inch display
nvidia gtx 765m 2gb gpu
i7-4800mq
16gb ram
240gb ssd
750gb hdd
external dvd reader
$2300
Pro:
- Lighter
- Smaller to carry
- Cheaper
Con:
- 3d card not as good
- smaller hdd
- external dvd reader
15inch screen
i7-4800mq
16gb ram
256gb ssd
750gb hdd
dvd burner drive
$2500
Pro:
- Larger screen
- DVD burner/reader
Con:
- Heavy
- $200 more
or
13inch display
i7-4800mq
16gb ram
240gb ssd
750gb hdd
external dvd reader
$2300
Pro:
- Lighter
- Smaller to carry
- Cheaper
Con:
- smaller hdd
Simple, first option if you can deal with the extra size. (nohomo)
am thinking this one;
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389935#!tab=specs
Intel® Core™ i7-4700MQ (2.4 GHz, 6 MB L3 cache)
NVIDIA GeForce GT 740M (2 GB DDR3 dedicated)
15.6" diagonal Full HD BrightView LED-backlit TouchSmart (1920 x 1080)
Weighs 2.5kg but has haswell, 740M & touch screen for $1000~
or the 17" non touch screen
http://www8.hp.com/au/en/products/laptops/product-detail.html?oid=5389947#!tab=specs
i was going to reply, but i see you have new options than the above...
i think i agree with leigh, if you can be bothered with the extra weight, probably worth it for the bigger screen and the gpu. not to mention if this is meant to be your daily work horse, you'd probably appreciate that extra screen real estate. not fussed about the dvd drive (heck, my pc doesn't even have one... ain't nobody got time for cd's)
Hey, yeah the more i research the more confused i get! and the more the budget gets pushed.
Now sitting at $2500 for a laptop; could get some nice rims for that price ~_~
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
