Think my parents have 24. All comes down to how good the inverter is I believe
Panels come in capacity from 170-250w ea.
4.9kw used to be the bigest ud see on resi. As thst was the limit for prem feed in (60c). But thats gone now.
Much more than 8kw and uve got a load of panels. Generally not enough room on most roofs.
If ur a high consumer or with young kids at home or retired, then it will pay off 5-7 yrs. else for most people its still a 10yr deal.
um, no
getting married just b4 then so will be on the honeymoon
I Have made the call tho.
first track day will be a couple weeks after back the tampered one on cup day
then the nov deca
and then nats at the end of nov.
so after a year off, 3 events in a month...booya
Not sure if anyone knows anybody who in final years studying medicine/nursing, but I've got a room spare at my place near Monash medical centre. $150 a week with all bills, bed + linen included.
Kind of sick of living with full-time students, but something like an intern or final year would be preferable. Will put up a notice at the hospital as I dont think ill have much luck on gumtree with the other 250+ properties...
Richo's famous. Vic time attack coverage on sbs
More to come next week.
Nsw round. Though I didnt have their camera in the car much. Would have been good, as there was some serious sideways action in the cold.
I think all the evos got the cameras.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
