So emailed telco to say that by paying full amount of outstanding contract to cancel means I sacrifice all my calls and data. Meaning they make full profit.
Said to them law is I cover companies losses from early termination. They said our offer is reasonable and that it is within my rights to pursue with TIO.
So I have escalated to TIO. Will provide update soon.
I thought you already went to the TIO
You should have gone in much harder I reckon (that's what she said)
They're unable to provide you with coverage, and you're potentially paying out their losses? f**k that noise
Yeah I did. That's when Telco called and gave me their offer. Responded via email and didn't budge. So escalating through tio
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
