Yeh really good. Recommend the carnival cruises for when you CBf organizing accommodation, food, entertainment.
Everything was actually really good!
would love to go on a cruise, but with the inlaws living in port douglas/cairns the wife wants to go there 3 times a year. i dont mind it but it gets boring.
who was the company you went with bro? what was the age group like?
"Any foreign currency transaction charged to your
account where the merchant or financial
institution accepting the card is located outside
of Australia. 3% of value"
Now... would you guys expect to get slugged this fee when your card is refunded to (not charged) ?
Carnival spirit.
Went to noumea(new caledonia), marè, port Vila and Vanuatu.
Age group varies a lot, school holiday as well, but majority was 20-35.. Out of the 2000+ guest
I actually barely got bored. Heaps of plays which I wasn't expecting to be so good, service is great, meet heaps of people.. Almost as if 10 days isn't enough, but when is any amount of holidays enough..
So Warner Brothers is making a sequel to Bladerunner
and for some reason they chose NOT to go with Ridley Scot, and to chose this Transformers-directing, CGI-worshipping, plot-ruining dickbag,
He has decided that the movie will have heaps more special effects, and will "stand up" to current CGI fests like avatar, etc.
BUT
He has also stated that in Scott's original, the viewer had trouble working out which characters were robots (replicants) and in his version the viewer "will definately be aware which characters are robots"
THAT WAS THE WHOLE POINT OF THE FILM YOU f**kING MORON!
IT IS A MOVIE WHERE THE MAIN CHARACTER'S JOB IS TO WORK OUT IF PEOPLE ARE REPLICANTS OR NOT BECAUSE IT'S IMPOSSIBLE TO TELL
ALSO, THE CRUX OF THE WHOLE FILM IS DECKARD WORKING OUT THAT HE IS IN-FACT A ROBOT BUT NEVER KNEW.
FFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUU
  • Like 1
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
