^^ THIS!
Can confirm driving Euro is a slow death. Current daily is a 2001 auto astra.
Had to put this in my driveway for a day or two to remind me of what its like to drive a real car (even though its technically euro... but I guess so is a honda accord)
If it makes you feel any better, it's powered by Japan :)
haha yeah forgot about that. old had k series, then 2ZZ from corolla sportivo + supercharger, now they're running their own 3.5L V6.
best 4 cylinder setup I've driven by a mile. but I wouldn't buy one...
Actually the V6 is not a lotus motor either.
its the V6 from the TRD aurion
http://en.wikipedia.org/wiki/Toyota_GR_engine#2GR-FZE
So an aussie developed version of a Jap motor in a euro car.
o rly? wasn't aware of that. probably best to leave the important stuff away from the Brits :P
paper work is filled in.... just need to get a bloody passport photo! so ill have to post it monday....
Good work Paul. What is the next event your planning on entering?
FYI I just used a Facebook picture and sent that via email :thumbsup:
very clever.........
no idea tbh. im actually selling my skyline as i join sau...
but once the clubby is ready and i have all the cams gear for the car then ill look! might have a go at the hill climb at nats, other than that havent got a clue! i want something cheap and easy for my first time in the hsv. shes a big girl.
Hitting up No 2 on the list today for lunch:
http://theburgeradventure.com/top10-2012/
burger van that going to be up the street from work!
Looks tasty!
So an AD-JD-EUDM Car :rofl:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
