Drooool....
sstp_1101_14_o%2B1994_nissa_skyline_gts-
if youve got such wide guards, why not fit a set of tyres that fit?
This, thing would be so much nicer with wide tyres
Filled up V-Power at $1.75, spoke to the check-out chick and says that we apparently have heaps of fuel in Australia but they just like to play with monopoly with our moneyz....
too many people bitch about petrol, buy a diesel :P
Finish uni on Thursday, job interview at JB Hi-Fi on Friday. Putting my study to good use!
need mad hookups brah :P
f**k yeah, so close!!!
http://www.marinetraffic.com/ais/default.aspx?zoom=10&mmsi=259025000&centerx=152.9676&centery=-31.77556
at southland today and lady infront took entry turn too hard and hub cap flew off, hit a parked car on the grill and ran up the bonnet. wasnt sure if ti was hard enough to scratch paint, but you'd be pretty cut if you came back to your car to find someones hubcap on the bonnet.
aftermarket hubcaps are aids anyway.
Reminds me of my Dad's old Corona going over cow grates in Country NSW, hubcaps flew off and we had to go searching for them. The hilarious part was there was dozens of others from all sorts of cars and a few speared into trees.
Knox and all other shopping centres have the signs on the entrances which say "No Roller blading or Skateboards."
Eastland has signs on the entrances which say "Shirt and Footwear required."
/debate
  • Like 1
/debate
Haha, yes I have noticed that sign. It's about 200m from my apartment.
Makes me wonder how many psi are in mine... I haven't pumped it up in almost 4 years... hell, it may not have been pumped up since it was rolling out of the factory in Japan...
didnt you get BBS'? then RSRs?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
