not aceeeeeeeed but close enuf.
If i was making a 90's D-Mob reference you would be correct,
However I was making a much more hipster (and more awesome) 90's N.A.S.A. reference
Oh and I have it on wax ;)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
