Sounds like you've got a dead lock seat belt lol
Could be...
Going to try disconnecting the battery, do the belts then reconnect and see what happens.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
