yeh but technically he still did something wrong, even if it is dog the fact they walked on private property to defect lol
either way not my car his decision, I'm sure ACA would somehow turn it around
That is f**king stupid. How can alleged speeding actions justify an illegal defect???
He has a strong case and is throwin it out
If he was speeding cops would have got him for that too/instead. They got him for defect cause they had nothing on him.
Defect got a time written on it? If so, I'd get an alibi from work saying he was at work when the defect was issued therefore car was in his driveway and cop must have looked up address to locate his car.
Yeah he was at work when he got defected lol, was like 8:30 I dunno as I said not my problem so meh
A severe case of flamin mongrels being framin mongrels
Edited by UNR33L
Oh yeah Leigh, I was at gym the other night; overheard a couple people in the carpark talking about Petite. I interrupted them to show your brother's photo, they were naturally shocked. My folks coudn't believe that the police defected him in his driveway. I reckon if you put the vote to everyone in Victoria, whether the police should have the power to do this stuff or not, it would landslide pass with a no. People just don't know about it or don't care, because the people it actually affects are something of a minority. When will this shit end?
Eh I know what you're saying man but I'm just too busy ATM to cause a ruckus about it :\ plus it's not my car so I'll respect his decision.
Which gym fellows were they?
Edited by UNR33L
I can't believe that.
What sort of lowlife scum takes pleasure in being an absolute prick.
Fair enough, maintain the standards of the law and protect the public in general, but exactly what do the police achieve by inconveniencing people for no reason?
I would be fuming and not let that one go. Comes down to private property vs implied access and the fact that a registered vehicle must be roadworthy.
Anyway- if he does not want to pursue it further, fair enough, would take a lot of effort/time.
A wild ali has appeared.
Get well Hamo and happy birthday hipsterman.
Wouldn't really take much time, it'd end up in court they won't show and it'll be overturned but it'd still be halt a day sitting around in court doing waiting and not getting paid.
Would be worth it unless your days pay is more than the defect.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
