Yeah, maybe Saturday or Sunday?
Can grab a steam cleaner for a few hours as well and give the seats a good going over :)Clean off the happy stains
Location of said 'happy' stains?
lol.
I dunno. Never dragged before and ive never done a "burn out" so wouldnt even know how to warm up the tyres. haha hooning does teach you things sometimes
I'd expect under 13 secs (but probably keep getting 2-3 sec 60footers)
Organic clutch? It's not nice to it but it gets you away with minimal wheel spin, revs up to 4-5k and slip the shit out of it though first til about 4k then let it fully grip and shift the rest as normal.
Keeps engine in a decent torque region and isn't a huge sudden wheel spin inducing shock like a clutch dump.
evos not enough torque to torque steer
this, they dont make much torque (dat 2L 4 banger lyf) but make up for it with short ass gearing.
a stock one has like 300nm, standard modded ones with an upgraded turbo do ~450nm or so
lol nope. My wheels skip even just trying to drive off at the lights. dat 4-puck clutch plus +100NM @ 2,000rpm in FWD.
i got the kinugawa kit, has worked flawlessly so far.
Noice. Cheapest I see on fleabay is $65 +$30 shipping, though? Kinugawa web I see it for $45 (USD presumably) without shipping. But still relatively cheap, and have read that they are sweet for the purpose as you say (their turbos on the otherhand... lolz)
the emo launches hard if you do that, as soon as you start slipping the clutch you can hear the turbo start spooling and you are off.
6k clutch dumps are just too violent on the driveline personally, id rather replace a clutch than a gearbox, diff or transfer case.
i got it from ebay, what ever the price was at the time, fast postage and the kit comes with everything required.
their turbos dont seem to be that bad for skylines, for the emos you pretty much want to stick to the high flow stock ones unless chasing big KW numbers as nothing else gives as good response/driving feel.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
