I paid $33, my mum is a CA and still just threw her arms up in the air when she couldn't get me into refund territory...
Basic Normal Salary, no real expenses, thing that put me into negative was Savings Interest I think.... Need to plan my dodginess in advance for this FY.
I was only getting maybe $100 in interest each month?
I don't know, I don't need to understand these things, that's what my accountant is for :P
Edit: lol definately not that much, I'm trying to save for a house deposit, not to buy a McLaren F1 outright :P
Yeah I just don't know what I can put there!
I don't drive for work, just to/from work...
I don't have any uniform or need to buy anything out of my own pocket for work...
I don't travel for work...
I don't really do any training or anything that I pay for out of my own pocket
We have a Ned Flanders here
birds. whens the monthly newsletter jew mate?
When I can be fked writing it haha. Events dudes give me no help writing the articles :(
Stop doing a good job of holding me accountable!
after a retune from Burnzy with the mr turbo and cleaning up my shit map from CREATD the car was amazing to drive, power all through the rev range and no knocking lol
I can't wait. Just need bank balance to recover before I can throw money at it... :P
Keeping one eye open for a good deal on an E9 turbz etc... hoping it doesn't pop up when I have no money haha. I think this is the most temperamental of my planned round 1 of mods
What about all those suits you had dry cleaned?
And driving your car to visit vendors?
Those logo'd work shirts you were required to buy?
Tax time was good to you Toby?
If your accountant didn't get a good return
You're gonna have a bad time
No big refund, need to find a new accountant
Seems as though as your mum is too legit.
Just like the Matrix, some of the rules can be bent
  • Like 1
go 8mr turbo, cheaper to buy and direct fit
9 turbo needs a fitting kit which is another $100ish, not worth the hassle imo
/watchedtoomuchmatrixlastnight
I blame all my illegally carried forward deductions on deja vu
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
