vs waiting overnight outside a nerd shop to buy a computer game on the first day of release?
i feel comfortable in my choice
already have SNES... needed a new 64 as mine was "accidentally" thrown out in the hard rubbish along with my NES
Who said I waited? Lol I went during lunch the next day
I never said you waited, although half my Facebook feed did... I need new friends :/
I am fairly sure you did ore order the latest daft punk Album only to receive it after everyone who just bought it from the stores didn't you?
wasn't that birds?
that awkward moment when you buy a set of 4 rockers, try to picture how only 4 are needed for an SR20 but ignore the thought as you are not sure only to find out that 8 are needed, your suspicions were correct and now you cant find any for sale anywhere other than shady german/russian/japanese websites.
Yeh that won't be happening again. Nah I just picked it up the next day.. Is actually quite good.
Well SR does stand for smashed rocker
my old ones were just worn from the springs/cams being rooted.
note to self: if ever parting out car, part out every single GTiR specific bit and put on ebay = profit
^ I'll come just for the beers :P
Btw, in other news...
Fast and the Furious 7, 8, and 9 greenlit.
Although the fool from #3 (Tokyo Drift) is returning for them as one of the main crew :/
I just Han to be alive, somehow :')
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
