vs waiting overnight outside a nerd shop to buy a computer game on the first day of release?
i feel comfortable in my choice
already have SNES... needed a new 64 as mine was "accidentally" thrown out in the hard rubbish along with my NES
Who said I waited? Lol I went during lunch the next day
I never said you waited, although half my Facebook feed did... I need new friends :/
I am fairly sure you did ore order the latest daft punk Album only to receive it after everyone who just bought it from the stores didn't you?
wasn't that birds?
that awkward moment when you buy a set of 4 rockers, try to picture how only 4 are needed for an SR20 but ignore the thought as you are not sure only to find out that 8 are needed, your suspicions were correct and now you cant find any for sale anywhere other than shady german/russian/japanese websites.
Yeh that won't be happening again. Nah I just picked it up the next day.. Is actually quite good.
Well SR does stand for smashed rocker
my old ones were just worn from the springs/cams being rooted.
note to self: if ever parting out car, part out every single GTiR specific bit and put on ebay = profit
^ I'll come just for the beers :P
Btw, in other news...
Fast and the Furious 7, 8, and 9 greenlit.
Although the fool from #3 (Tokyo Drift) is returning for them as one of the main crew :/
I just Han to be alive, somehow :')
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
