start getting evidence toghether. they contacted us a year from taking the money. ask for all sorts of shit. then a year after that is when they process the permanent part. which is what they are doing now.
Yeah been taking photos, got a joint account etc
Are you actually married or just going for PR from as a defacto?
we where defacto but now married.....
they dont ask for photos tho dude.... they ask for bills, post etc. mail with both your names on and stuff....
we went as far as to invite my officer to the wedding..... she didnt turn up lol
When my uncle married someone from China they came around and got a bunch of photos with us in late January, and we had to put some stuff in the background to make it look like it was Christmas day, lol
are you serious? hahah! thats brilliant!
just thought I'd see whats going on elsewhere.. Seems the QLD Whoretown is always full of VIC & NSW peeps :yes:
yea sorry about that. they dont like poms in here so i hang out with you guys.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
