well thats the trick. not panicking. its not easy to keep calm.
but do it.
growing a beard helps.
SEE MOFO's ... I got this shit on lockdown
Yeh but that's what I mean. When people say I would've run all of them over, I can't help but think its a lie. You'd run, your instinct would be to get as far from them as possible especially when your wife and child is in the car
exactly... what I mean is if they were in front of my car and my child was in danger because of them attacking me, I wouldn't think... I would just drive over what ever was in my way to get him out of trouble... if they were in front of me... well that would be extremely sit for them but bad luck... that is instinct...
clearlt I dont mean line them up and run them over individually
yeh I wasn't saying you in general, just what you said just reminded me of other ways some internet people act
poor insuranceless citizens trying to have healthcare forced upon them.
what if they want to pay for medical treatment that they cant afford out of their own pockets?
they should have been donating their wages back to the gov't to make WEAPONS!!!!!
in other news, went to work on Monday and they want a letter from my neurologist stating that I am fit to work and to have her devise a return to work schedule
so i'm now starting on monday doing 4 hours a day for a week, then 6 hours a day for a week then full time :)
awesome employer is awesome
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
