I've had a bike do that to me before; slammed his brakes on in front of me and looked pissed off when my car hit his rear wheel...what the fk did he expect to happen!
There was one on jalopnik recently too, on a freeway - needless to say the bike didn't fare well
I still think there's a lot more to the story. If that was the case and the above happened, instead of beating the shit out of him, wouldn't they put him under citizens arrest(or some other stupid American law) until the police arrived? It's like pot calling the kettle black. And in the initial run over, it pretty much does look like they surrounded the SUV. What else would you do with your kid in the car.. I'm surprised no one pulled out a gun.
exactly. they have it on video.
like i said, pot calling the kettle black. theres too many holes in it to be one sided for the bike group, where it makes a lot more sense for the SUV driver to be put in a compromised situation judging by the amount surrounding.
They weren't, but it was no misses, no hiccups, pull after pull after pull, hours of it... IC was cold, AT Cooler was...room temp.
240kw @ 4000... and 310 at 4800...and 5k,6k,7k, 298 at 7500 etc. Did lose some boost, 26psi in middle, tapered to 21-20... prev run was 24? at redline.
Did a 98 run, 26psi (down to 21-22) and made 250kw lol. Same graph shape, though. 16+ deg of timing and no pinging.. 22 or so on E85.
Nothing of note changed (well transmission build occurred/new trans but went from a built NA to built turbo one).
Fingers pointed at IWG blowing open or manifold, or turbo being choked, though no reason as to why it should be any different than before as nothing changed...
Should prob clarify
First trip time, 20psi, E85, made 310
2nd trip/retune, 24 psi, E60, made 340, ran out of duty.
3rd trip/retune, "26"psi (down to 21?, E85, made 310.
Prob seems due to boost, but nothing changed :P
i know my emo makes a big difference to power if you can keep extra boost in it to the limiter.
is shingeki really that good? its all despair and gore isn't it?
oh yeah newish roast duck joint @ box hill called roast duck inn is pretty good too, up there with rock kung or might even be better, though i dont think they do peking duck.
soup dumplings are pretty damn bloody good.
good guy NAB
Well I was technically referring to my Ops Manager but i didn't really make that clear :P
Dat hub dyno reliability
only thing more reliable is your mother
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
