Mine really is a stroked neo, and cams, and some headwork blabla its a 2.9 kit but the pistons are slimmer than what you'd need for 2.9l displacement
It's also an auto.
Its also a highflow
Technically bleeding boost up top is nice and safe.
Technically 310kw (at 5k, and 6, and 7300) with 240 @ 4k in an auto is a 'good' result, but more is always good lol. y'all know how it is
I also have flex fuel, and its very useful and tbh I wouldn't have it otherwise, even though I work 200m from an E85 servo.. Or caltex in my case. I dont know of any United in Clayton where I work, which is a bit sucky. Either the united page is lying or I just can't find it.
Its worth it just so you can see the panicked attendants try and stop you filling up with it at bowsers which happens to me i'd estimate at least half the time
It's also an auto.
Its also a highflow
Mmm Interesting build
Sounds like you need a build thread if not already?
No, as it is wraught with pain and disaster, years and years and years and years of it.
WHen people say "it could be worse" - Thats me. I am that guy. There is no worse, from my perspective.
Wow, you're still at it! I remembered you having issues with just na+t years ago...
would be very interested in build thread greg.
should look into that.
Dooo eett.
I'd read it
I mean how many built Neo's are there in Vic? Hardly any at all
IIRC Trent had a 34GTR pushing well north of 450kw through there with a custom dual pump in tank setup. Something to consider.
he did, but my opinion is that if shooting for 400+ then no farks given for stealth or legality
CrispyFries, on 02 Oct 2013 - 17:09, said:
lol @ the newbies that don't know of the kinkstaah epic story
Mine is an extreme cautionary tale, if it was ever non-horrifyingly bad I'd have made a thread... gone to an event, or a track day, or a cruise.. or.. come out in public.. was off the road for 3-4 years in a workshop that I will not name.. not entirely their fault either, or mine. Just bad for everyone involved..
The road is less travelled for a reason sometimes..
TLDR: Mistakes were made. Everything has broken. Everything was replaced, results still quite bad. :P
I thought the same, like, laughably so, as in, why would you even bother.
Then I heard a couple of hilltop hoods songs, and I thought, well, its kind of catchy. Only those though. I still think other than exceedingly rare examples.. its just, no.
http://www.celebritynetworth.com/richest-celebrities/richest-rappers/snoop-dogg-net-worth/
celebritynetworth.com puts Snoop Dogg at @ $120 mil.... proof positive that Kurupt still doesn't give a fuck about a bitch
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
