whats all this abaaaat then?
Just a post on a FB about selling Alex's car
I know Alex (alr3x) sold it to another guy on SAU here
Just thought it was strange the link posted on FB goes straight to Alex's old SAU for sale thread
ahhhh. i thought we had a thief linking the car for sale to sau....
Might be a theif if Ric thinks it's stolen
Dont know the deets on that
Or maybe his just posting pics because he likes the look of Alex's car. Not sure lol
edit: seems like the latter
Edited by blah_blah
Off topic
Birdmang you going to Singapore yeah? Is this for holiday or for Laser eye surgery?
Was going to do it but won't have time. Apparently need to go in for check ups and shit after so, didn't bother booking in. Will probably just get it done locally so I can sue someone if I go blind.
Will be in Singapore from 23rd to 8th with stops in Malaysia and HK for happy times.
Marina Bay Sands come at me!
You got yours done Leigh?
If so price and place of yours?
Im thinking of getting mine done.
Yeah mine are done by these guys on St Kilda road http://www.visioneyeinstitute.com.au/locations/victoria/melbourne/ they're meant to be the best in Melbourne.
I think it was a bout 5.5k it's great I highly recommend it. Going on about 2 years now.
Edited by UNR33L
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
