You shittin me? They cut your eye while your watching? Or can't see cos mostly blind prior to incision?
Yep they hold it open with clamp things cut flap, fold flap over laser and reshape eye, put flap back on. You loose vision for a little but all good.
Edited by UNR33L
sooo.. new season,
strike the blood
outbreak company both brought some lolz.
Have some episode ones downloaded, just haven't had time to watch yet!
Recently watched danganronpa which I didn't think was too bad, but apparently the game is heaps better. Reminded me of 999 game, which was pretty fun.
I heard that you can smell getting your eye burnt whilst doing laser eye surgery. Haha
yeah smells bad, they tell you it's the machine and not to worry about the smell but i'm a bit sceptical
Did you get Lasik or PRK laser eye surgery?
I heard PRK is better but has alot longer recovery times
Lasik you pretty much have the vision straight away
ASLA is a refinement of PRK
1 week vs 1 day for Lasik :-/
http://www.sydneyvision.com.au/index.php/alternatives/
Yeah i've heard mixed reports. Some people are fine after a week. Some have taken up to 3 months to heal and reach 20/20
My brain has exploded reading so many pages since yesterday from this forum. Its quite informative
http://forums.whirlpool.net.au/forum-replies.cfm?t=1258336&p=79
Lasik, I think my cousin had the other one with the implants or whatever but took a little longer to recover it depends what your eye is like.
Mine were nice and thick plenty of space to play with and do the good way.
Edited by UNR33L
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
