I finished story mode tonight, and sitting on 86% completion... will work my way towards 100% slowly :)
fair effort.
what properties do you own/recommend?
what a beast. so much toob.
http://www.speedhunters.com/2013/10/have-wings-will-fly-inside-the-peugeot-208-t16-pikes-peak/#chapter-making-history
fair effort.
Well you can buy a whole lot of properties with the money that you get from The Big Score near the end, the final heist... and you only need to buy 5 properties for a 100% hurdle... Honestly you're never going to get a lot of income from properties compared to income from heists... But I recommend getting the property with the wooden staircase down to jetty near the top left of the map, this lets you go track down nuclear waste in the ocean at $23,000 / barrel... But as I said, you don't need money in the end...
5 properties eh?
I have 2 bars, los santos customs, smoke on the water and the sonar property. Sonar was a good buy, others arent all that special. Thought maybe some might have had their own mission set or something. All my characters are rerally poor except for trevor who did well on the stock market lol
Note: Los Santos Customs is so annoying being out of the way. feel a bit jibbed only accessible to one shop and one character. oh well, no such thing as a free lunch
Yeah I meant story mode...I'll keep playing and go for 100%, but I get bored easily so we'll see.
Does BAWSAQ or whatever it's called work for anyone else here? Mine always says down for maintenance, wondering if it needs an internet connection to work coz mine hasn't been connected lately..
My mate got to 100% the other day, a lot of time spent finding shit etc
BAWSAQ is linked to the global usage of items in the gta universe, people (players of the game) buy a lot from Ammunation, stock goes up. People blow up a lot of FlyUS planes, stock goes down.
I've been doing stunt jumps and stuff... but something went wrong and now its bugged a bit... Says "undefined" instead of the completion count... so I'm missing 1 of the 50, but don't know which :'(
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
