$686 still lol
Yeah was sent by a UK company they only paid 75 pounds for some reason
Overseas > Aus postage always seems ridiculously cheap compared to Aus > Overseas. Window visors I had to send back to Japan(Which ended up being bounced back to me -_-) cost me over $50 to send back but the yen value on the original shipping labels only worked out to be about $15.
I gotta move to different store.
Spotted my old R 5 mins after finishing work, didn't realise until I saw superlaps...
Anthony, if you happen to be reading this, what kelvin are your headlights?
Where abouts Grant?!
I'm running 6000K Kaixen kit from OTR.
Had cheaper kit from autobarn before but one kept going out..
Saving for those S3 xenons lol
Fitzsimmons and Reynolds, around 11.05-10, I went opposite direction to home.
Your lights are so blue, I thought it was a 32 for a moment there...
Didn't realise it's you until I remembered you'd replace the panas with superlaps.
And can I have the panas back? Pretty please?
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
