These are currently on a boat headed to Melbourne. Excited! Anyone ordered from streeter that can give me a rough idea of sea shipping times? Is it actually 9 weeks cause i'm gonna go crazy waiting :D
What sizes did you get? Import Monster currently have like 30 sets sitting in their warehouse waiting to be sold.
Panel off genuine Nismo Race car signed by drivers...delivered to my desk...all for free....booyaa
should be an entertaining return to work
what would you do with it? where would you keep it?
if someone gave me a door or quarter panel signed by someone i'd never met, I would probably sell it and not bubble wrap it.
this surprises me,
When I was in Brazil I checked out some stuff, (mainly electronics) and everything was much higher than AU prices.
Locals I talked to said massive taxes on anything not built in Brazil??
i went to markets back streets etc, NOT the ghetto, but yea. was all prob stolen. middle east is pretty cheap too. iraq, afghanistan etc for obvious reasons.
Went conservative:
18x9 +30
18x10 +38
And got em for 1500 so a fair bit cheaper than IM to my knowledge.
it's a give away for SAUnats actually.
i be out of space for anything at home.
to be honest I have no idea.
ATM all I have been told is a panel from the bathurst Norton cars signed by the drivers. they were waiting for after the race to see which ones they could use.
and I haven't been in the office since the race.
it's to be one of the give aways at the dinner, plus something else for the merchandise packs.
after we move I am thinking of grabbing one of the bonnets to chuck on the shed wall. have to wait and see how much space first tho.
"Honey, I need to spend some time and money working on the car, or it'll leak oil.... on the new carpet... You wouldn't want that would you?"
No need.
Fluids are somewhere in the grass area when the R died.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
