Don't listen to Hamish mate he's angry at the world and the popularity of D1Rs. They are a great looking wheel, but like all cheap wheels, will have your wheel balance issues above 100km/he unless you get frequent wheel balancing.
I get cheap wheel balancing and alignment so not a major issue on that front. Just can't decide on which one to go for. Dish or concave? In terms fo fitment they'll both be pretty similar going by pics.
Do like. but dont like the outter bolts. paint that shit black.
as for gloss or matte... matte will probs go out of fashion soon
True that mate, good point. Might consider getting the studs black too, didn't think of that.
If the wheels are brand new in matte black, is it as simple as getting a place to clear coat them to make them gloss? Or do they ahve to strip the matte off and re-colour in gloss black?
Ahhhh I was thinking the exact same Varrstoens as what you've got but the only offsets they offer are +20 which, believe it or not, are too aggressive for the fat VE guards. A bloke had 19" Varrstoens like yours on his VE and he eneded a lot of guard work apprently. Tough look though.
you can get custom offsets made just email them thats what i did got custom up front
Really?!?! f**k yeah! Do I contact the aussie distributor or Varrstoen directly?
And do they do them in 20s? 19s Are too small for the big VE body :(
Pulsar is up and running, hopefully pick it up tomorrow. Will put up a vid of first start tonight. nothing sounds better than lumpy cams and an incorrect base idle. aw yeah.
Engine will make track debut at Sandown Christmas
Dat silent exhaust tho
needs straight pipes :woot:
haha it's loudish up in the revs under load but I like the silent killer spec atm :D
straight pipes is just stupid loud some people on forums have done it lol
Just add them on facebook and send them a message, main guys name is John I think
Dat photo!
Dem photo skillz!
  • Like 1
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
