annoyingly had to rma my new motherboard :( at least the store swapped it over straight away, gotta reinstall then straight back in bf4!
good to see Webber on podium for last race! also dezzmang you're crazy staying up for these late ass races lol
Edited by UNR33L
I didn't stay up...I woke up after a 3 hour sleep watched it then left for work.
Dedicated
I tried that for the U.S one.. didn't work to well ended up falling asleep (probably cos of vettel)
So.... who remembers when I said the 32 was going to be a dodgy track hack on a budget?
Just broke the "should have bought a bnr34" barrier.
but passion comes at a price. So does quality (as doing your body twice must have been an excercise)
and f**king good luck getting 120-140kws out the micra. fo real
body wasnt actually anyones fault other than mine.
i rushed the panel beater.
this time i let him take his time with it and the end result is amazing.
excited to drive it with the new clutch. lol
whoops meant hp. my bad!
