Duly noted, thank you peeps. And thanks for the butter recipe Ham. Omelettes are badass and their simplicity and low mess make them win at life. My omelettes are so busy I have to use a handful of cheese as a binding agent or it goes Hindenburg on me...
Would love to add vegetables for texture, but I don't want to mess with my all meat tastes. Parsley as a pub meal garnish is as far as I would go!
the humanity
Waxed bonnet, then cbfed the rest of the car so now I have a nice smooth bonnet but nothing else :D
Dat arm / shoulder workout rubbing that bitch off
Edited by UNR33L
Yuck what for?
was driving normally 5th gear doing about 70-75 in a 80 zone coming back home from work literally 2 mins away from home yellow one pops up out of nowhere tailgaits me puts the lights on and shit. Partner was a good bloke but main guy was pretty rude. He warned me for my rear licence plate for being bent and unable to read from a 45 deg angle. Got a fine for driving manual on auto licence (my fault for not booking my test sooner so not complaining left my car at site and walked home) but also for "failing to display p-plate rear" even though it was up and on factory uv cut tint that has passed Rwc he said he couldn't see it and gave me a fine and 3 points....I was on 1 point before this so licence is bye bye unless I contest. :(
I got done for the EXACT same thing.
It would of been 4+ years ago, on my P's in my N/A R33 just when green P's were just introduced.
Pulled over - done for manual with auto license (had the re-test booked but you know vicroads delay and what not, fair enough $150 and my fault) Then also said P plates not displayed cos you couldn't really see them that well through the tint, and with water on the rear window. $150 and 3 points for that as well, I wrote a letter to Vic faggotpolicegayflamin mongrels and got out of the P plate thing. From then had to display them on outside of car with magnetic P plate on the back which were sometimes taken but meh.. got through my Ps eventually.
Then got a 33r off Ps, random EPA etc in the mail and just had enough in general sold up and got a ford, buy a ford. inb4grant
No points at guessing which flamin mongrel pulled me over ;)
Edited by UNR33L
  • Like 1
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
