drove past doncaster westfield said 7 parks left on the sign - was like 150 cars lined up to go in lol..
Soooooo glad I don't work there anymore!
So this is what happens when you don't clean off shit from the car for a long time....
quick! better take it to final inspection and spend another grand on it
Just got back from Knox...
Drove straight to Alcatraz (caged parking area at the back) and got a spot within 15 seconds.
Walked around for ages, even with 40-50% off prices are still more expensive than buying online (including shipping). *sigh*
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
