Alvin you were still using a blackberry? hated those things used to have em at work for a bit.. before we rolled out iphones
And yeah I got pulled over the other night doing a hill run we (me and 2 mates) came wildly fast up on a car in the dark that said "highway patrol" lol, just checked out our bikes and said be careful and we'll wait here for a few minutes.. you guys go ahead ;)
may have seen those... they did a vtec vs ve battle ive seen. but will watch those when i get a chance.
Google maps saying heavy delays on peninsula link but cant find out why or where...? anyone got a sitrep? need to hit um some cheeseries
Yeah block with a rodeo and a massssive caravan lost control and ended up an embankment near a bridge, southbound near moorooduc
http://www.vicpolicenews.com.au/news/2261-peninsula-link-closed-sth-bound-in-moorooduc-following-crash.html
Just slightly over the tow limit I'd say ;)
Was with a friend last night at about 2am driving in berwick to drop food off to someone, turned out of a street, saw 4 cop cars to the left of me and 1 highway patrol booking someone, according to my friend that was pettett. Lucky me he was too busy with someone else =D
Lol I love watching those driving clips, the Japanese drivers are always laughing and yelling lol sounds like they are having so much fun :P
Haha yeah, this is my current favourite.
https://www.youtube.com/watch?v=NDxi0ot3rkk
Love how oldmates dressed so casual and driving so casually chucking all these, at the time brand new workshop demo cars around on the touge.
jesu christo... big caravan or not, would take some sort of effort (other than sleeping) to travel across and exit lane and up the embankment.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
