Don't know if it's already been mentioned but you can all permanently remove your rego stickers from today :)
oh so no more rego stickers will be issued?!
can you remove them or does the current one need to run out before it can be removed?
If your going new ham it's hard to go past Hyundai / Kia as much as I'm not a big fan what you get for your money is quite generous leather etc (great with kids) and 5 year warranty and stuff hard to beat..
Not sure probably wouldn't risk it I got
My renewal which has no sticker with it so I'll pull my sticker off on the end date
yeh... prolly ex demo to save some coin
leaning towards the 2.5l 2wd mazda cx5 maxx... recon i can get that at 30... but the hyundai is a strong competitor
So driving on the highway, my rear left tyre blew on my stag while driving with a full load plus a loaded trailer... then when loosening the nuts, two studs broke off. Wondering how many more studs are cross threaded from the other wheels.
My adventure in Riddells Creek.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
