ayayron wont be going to reservoir.
and #@Miguelone what's the part number for a 33R alternator?
There's 5 different part numbers, 2 for a Mitsubishi Alternator and 3 for a Hitachi alternator, different revisions depending on what year the car is. 20/25/26 are the same for 33. They're all around the same price though. LMK what year you're chasing and I can grab that P/N. I have a VGC S2 alternator if juan buy too...
Oh, this wouldn't happen to be for a Brandon Loong would it?
Sweet son of rajab f**k Misty's went down the shitter years ago.
Go anywhere else lol
the trick is to not go in expecting much, the return is much better as it exceeds your expectation lol
Nah... Went there before they expanded (couple years back) when it was Misty and 2 other workers in the entire place.
Every meal got worse every subsequent visit. Thousands of better places to utilize an appetite in Melbourne..
(Or just go round the corner to soda rock for a burger)
ah yeah, its for brandon,
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
