aftermarket bov is super retarded on a street car that the stock bov can handle
when you pop the bonnet you might as well call the cop a fag too
Agree.. After market bov is waste of money. Should've just got and. 8MR bov if u wanted an upgrade..
Will be increasing boost, don't think stock 8 will be able to hold. 8MR bov was the other option but it's pretty similarly priced, so the TS should be good choice for me. Dual Port for options, but emo doesn't like atmo usually anyway iirc.
:( I was gonna book my car in for a tune @ Chequered next Friday... except now it's forecast to be 39!? Anyone shed some light on a full tune being done on a hot day like that?
I wouldn't recommend it...
When tuning you push the car hard to find its maximum, then you take out a little bit as a safety margin to accomodate for hot days, slightly different fuel, etc... If you tune on a crazy hot day then the maximum is going to be lower, and then you're never going to be sure just how much of a margin to take out... My last tune with Trent was fuarken hot, think it was a 40c day. His ventilation is pretty good, but it was sucking in the air from above his factory through the roof which was still pretty damn warm so the car was getting really hot and pinging off its tits.
If you can reschedule, I would... but who knows their schedule and when they can fit you in next.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
