The ralliarts are ok, it's just standard lancer with a nicer gearbox/engine and evo 9 awd
Brakes are very much street spec, don't expect them to handle much spirited stopping before fading, suspension/back end feels a little nervous in higher speed corners. Disregard what the gearbox service intervals are in the manual , 40k km or less if driven hard and then change the filter and oil.
Mum just bought a 2012 Honda Vibe-S. Such a cute little car and I never thought i'd say it but it has such a nifty, useful interior: loads of room for such a tiny car. VTEC will kick in on the way to Coles for sure.
In other news, PowerFC tune booked in for next Monday @ Chequered, can't wait!
Curious when you sent the original booking message and how long they took to reply
Im also trying to book my car in lol, considering going elsewhere if it takes too long
Cat took a while to reply to my first few messages, but they have just gotten back from Xmas break and apparently had like 200~ enquiries over that period lol.
Try calling instead of messaging!
Yeah I know they just got back from their break
She normally replies in the order she receives the messages
So was just curious when you sent your message so I have an idea where I sit in the queue :)
Sent 1st message last Wednesday, didn't hear back for 2 days, got impatient and called.
Jumped the queue? Maybe.
10's start at double what a standard 7 is worth.
pretty sure this is what he meant by trading up ;)
They are a good option if you were going to buy/lease one new and novate or salary package.
As a second hand car and something bang for buck, 10 doesn't come close to 7-8. 8 with the 6spd is currently best bang for buck imo. 6 months ago it was the 7, but the 8's have come down.
Just have a look at prices of 9's they are stupidly expensive.
and this is exactly why I have a 7
build my simulator you ass
you want a simulator of scott's ass...
even for you that's gay
anyone been in a current ralliart?
what's the interior quality like? I know it came out 4-5 years ago, has it had any updates?
Madden's brother has one in Brissy.
It's an ok car, but requires a tune big time. There is no power what so ever under 4K, they have neutered the poor thing.
Also fuel consumption is not a strong point (13L/100 is their average).
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
