Whoah Birds. Didn't know you were still around! Haven't heard from you in years haha. Message me some time dude. Would love to catch up!
I never leave. What car did you buy?
V35 350GT coupe!
Payed the deposit today. White. Coilovers, exhaust, sound system, leather/woodgrain interior. 30,000km on the clock and absolutely immaculate. Gonna be such a great daily!
As for my MR2.. it's dead lol. Parting it out as we speak.
That's all I missed in 3 years? Well that's a bit anti-climatic.
Play one of my songs at the funeral so I get royalties, thanks :)
ill use one of your songs, his deceased estate can pay the royalties..
  • Like 1
V35 350GT coupe!
Nice work. Get black tail lights / tint them, looks awesome on a white 35.
Still rockin my R33...it's quite a bit faster than when you last saw it, though.
V35 350GT coupe!
Congrats
Come to the next SAU event :thumbsup:
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
