such troll, many anger :P nah but srs 8k rpm is nuts should be amazeballz shouild be a 10sec in that with the right setup of suspension / tyres / clutch (not that you care about the drags really)
Lee, just kicks in straight up and holds boost the same level throughout whole rev range basically
Edited by UNR33L
Yeah can't say I've ever been keen to enter a drag day
Happy to drag you down the Sandown front straight as some of the other boys do :P
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
I had RACV roadside when I was 18 years old. Crashed a car, called up to get a tow. They said sorry can't tow you for accident, only if your car is broken down. I said I can't drive it, it's broken down, I need a tow. Sorry, not for accidents.
Canceled membership there on the spot. Useless dream boats.
I forgot about that, Birds. Also happened to me when I was 18.
jealous of Tony atm. my manifold hasnt arrived yet :mad:
car heading to workshop on wednesday for intercooler piping and other works. need to decide on BOV, catchcan and coolant reservoir. cbf. can forsee it now: ill buy something and it wont fit, or be too small or something much more suitable that i didnt know about etc.
Thats the problem with "generic" or misc. items. never sure how much effort you need to go to to fit stuff. and oil fittings... fark that shit. a world i dont want to get involved into.... stupid imperial and pipe measurements.
Tony could beat Leigh with some serious grip and a drag friendly suspension setup. Need MT streets or something.
Then again, hub dyno, Leigh might just get him even with traction.
Bed-Stuy, the place where my head rests
Fifty shot clip if a n***a wan' test
The rocket launcher, Biggie stomped ya
High as a motherf**kin helicopter
see you THOUGHT I was gonna do that
Leigh's car WISHES it was tuned on a hub dyno...
you wish your car was tuned on a hub dyno
hub dyno
Dyno dynamics is how we roll
not me... I prefer accuracy over wheelspin
of course in saying that my evo was tuned at chasers...
on a dyno dynamics...
and has no where enough power for wheel spin...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
