I need to install a double din head unit, speakers in the front and back, a sub and 2 amps, anyone know anyone/place that installs all that for a good price and does a good job?
I asked jb hifi how much to install all that and they said $650, even i know thats a rip off.
do it yourself, $time is all it costs.
If only this one wasn't nearly 5k over-priced. Has D1R's with it tho.
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2427313/?Cr=19&sdmvc=1
i don't think that's 5K overpriced for what it is / particular market, but i'm biased hahaha
you people is cray
For serious, wtf.
My last quarter(After realising they'd changed us from peak/off peak to one rate and making them fix it) Was only $220, at the most we're talking $400 or so.
were your houses built without light switches?
are you trying to run a legitimate marijuana stash in your roof?
do you have more than one large chest freezer to store antelope you shot in the savannahs of Tanzania?
would continue but need food. If im bored later (and I will be, because motel) ill come back to play 20 pictures of tacos in 20 seconds.
that looks dodgy as, why not even wash a car prior to posting pics for sale? dirty as engine bay, why need 3 air fresheners
plus 13500
ha
Experienced eyes see so much more than a noob. Thanks for pointing that out it was probably a smoker's car or used to transport a dead body or something.
Edited by bucket_boy101
customer : do you have wifi?
me : no
customer : why not? my ipad won't work without wifi
me : how does that concern me?
stupid kids. if we had wifi, tightarse 7$/head spenders like them would flood the place and the restaurant would close down.
fancy that, four kids, all under 16 it seems, comes in orders two soft shell crab rolls, at 15$ each, orders nothing else, drinks only water, sits for 3 hours, and asks us for wifi? f**k off. oh and paying like 20% of the bill with 5 cent coins. srsly?
epic troll effort if they were not just broke ass kids trying to dine out.
Edited by xALmoN
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2526056/?Cr=5&sdmvc=1
Anybody recognise this one and does winning awards make the NA worth this much? I don't think it does.-
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
