whole forum was down for aaaages.
and Birds, not a SSS. is manual though. and sedans are really light weight. Interior is pretty terrible though. from all the cars ive sat in at wreckers, not very pleasant at all. Its a good price, LX has spoiler and airbag. needs alloys and rear disc brakes though.
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2526056/?Cr=5&sdmvc=1
Anybody recognise this one and does winning awards make the NA worth this much? I don't think it does.-
I know this car, dude works at Jaycar in Bendigo. Asked me about my wheels ages back.
Tbh it's not worth anywhere near that. It is a tidy car but it looks like he's just added the original purchase price of the car and everything else and trying to flog it for what it owes him. Awards don't mean anything to the value of the car either, unless you're talking Concourse d'Elegance or something.
customer : do you have wifi?
me : no
customer : why not? my ipad won't work without wifi
me : how does that concern me?
stupid kids. if we had wifi, tightarse 7$/head spenders like them would flood the place and the restaurant would close down.
fancy that, four kids, all under 16 it seems, comes in orders two soft shell crab rolls, at 15$ each, orders nothing else, drinks only water, sits for 3 hours, and asks us for wifi? f**k off. oh and paying like 20% of the bill with 5 cent coins. srsly?
epic troll effort if they were not just broke ass kids trying to dine out.
Should be going to Macca's for better value for money if broke
me : no
Mmm must come try soft shell crab rolls!
lol @ $16500.... Even if it was a gt-t
That's like my biggest pet peeve in the automotive world; people thinking their shit is worth infinitely more than it is. The sheer arrogance!
*cough* 34R's *cough*
Nice
Getting it coated or leave as is?
Your manifold would be easy to go on
ETA?
Have you done a full tune on your existing setup yet?
dropped it off for coating this arvo. hopefully ready by thursday.
Car is getting dropped off for intercooler piping on wedneday. damn public holiday drags everything out :mad:
Didnt get full tune on current setup. Ace was busy and im low on funds at the moment. also got someone waiting on my current turbo, so dont want to hold him up.
im not much into muscle cars, but this awesome (tim allen, jerry seinfield, jay leno: too much money)
