Is there a place in Clayton South known to import broken Skylines, fix them up and then sell them at exorbitant prices? It's just I've noticed two different cars going on Carsales that are both in Clayton south under the name Michael. Unless it's a coincidence... Different mobile numbers are listed. May be a concidence and both may also be Monash Uni students.
Edited by bucket_boy101
