squizz try lambs or the nick stevel on sdu here the link to the ad
http://forums.skylinesdownunder.co.nz/show...&threadid=11262
he's ok I've dealt with him
meggala
Or work 48 hours a week here, get RDOs public holidays and lock down weekends, while still getting home at 4 everyday and earn 130k while not living in the desert working 12 hour days (forget what it averages out to)
No contest imo... Its a good idea if you plan to do it short term to set yourself up but most people seem to piss it up the wall on alcohol drugs and hookers..
hey brahs organizing a little meet and beach rd cruise tomorrow night, meet up at 9:00pm at the new bunnings springvale (849 prinny hwy), leave 9:30pm probably gonna go up beach rd to port melb and take photos under the bolte. Lemme know if you're keen :)
So thread has been inactive for two hours.
Go join the main chat thread in the wasteland. people talking about food and saying hello/goodbye to each other all day keeps the thread going.
Was hoping to make it to Phillip Island for track day this weekend but a) will be hot b) might have to prepare to shoot a short film c) if decide to go to beach whilst at PI, who's gonna want to come with to watch cars for a few hours? no wimminz thats for sure
inb4 everyone on wastelands earning on dat over 100K p.a
I might come
im working for a mates team at the classic car series down at pi on the 7/8/9th march, anyone else going?
You in charge of the beer fridge?
You gunna pik me up on the way through Lee?
I could. Bring bathers.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
