What did you get?
I bought a new Audi A5.
VW didn't want to know me when I went there both times, BMW same deal.
Mercedes and Audi were great help but I preferred the A5 to most things I test drove.
A5?
Baller
don't you work at coles???
I need a job change
I need a job change
I work on a target receiving dock these days, also I lease some farms for wheat and canola crops, sold some property as of late also which was nice.
Are you young? Happens all the time such bs. What engine did ya get? The 3.2 is awesome
Baller! Congrats, though!
Driving home from city just earlier
, saw an L plater in an A5. Such cool. Much jelly. Wow.
