oh man you'll love it you go the xenons and led's yeah? just leave headlights on auto and jump out at night / jump in at night and the magic will happen as long as you got the feature set to on - should be as standard.
nice i love those rims mines the older model so got the 19" Y arm style was gonna change em over but cbf don't think ill keep it much longer
like this -
yeah has the xenons and leds :D
that does look pretty handy!
yeah those wheels really attracted me compared to alot of others i saw
Euro V8s don't do it for me. Need dat dirty yank, big stroke firing order. All about the idle and the effortless low down, not the high up screams :/
with you 100%
Euro 6's, jap 4's (yes I know you won;t all agree to that) and yank 8's
next major build will be a hemi
so checked out a MB today, holy crap I could not believe the difference in service.
going to hook up a test drive when back from kuwait.
that said boot of a A class smaller than expected.
yeah their service was incredible when I went there also!
Compared to who? Beamer / VW?
As for Jap 4s, Euro 6s and Yank V8s...I'd actually agree with that. Though I think Jap 6s have their own lovely sound up high.
Best 4 cylinder I've heard was a 2T-G in a TA22 GT with Weber 45s. Shit sounded like a miniature big block.
So far the worst was VW.
BMW were ok, when they would eventually talk to us.
mazda were great as well, nissan guy was just sleezy
going to Volvo/ Land rover next
might looka at accord euro as well,
best 4 for me was a race spec BDA escort.
followed by a Datto 1600 with webbers/straight through zorst..
I know a guy at Mb melb if ya want someone good to deal with
Keen to see the gla amg when it comes out
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
